Tns510: Handsfree And Audio Bluetooth
Ludovic
Hi
I have a TNS510 in my Auris HSD + iPhone 3G
-I can use the handsfree over bluetooth just fine: the phone is paired, and automatically reconnects to the TNS510 when I switch the car on.
-When trying to play audio via bluetooth, it says that the system is not connected. I have to go to the menu/information/bluetooth menu and re-connect the phone every time: even tough it does says that it's already connected there, and prompts me to de-connect the phone, and then re-connect it.
Once this is done, it's fine, and I can have both handsfree + audio at the same time....until I switch the car off, and have to go through the bluetooth audio connection procdedure once again...
Has anyone else experienced this ?
Any idea ?
Thanks,
Ludovic
  • 3 months later...
Hi Ludovic
I have exactly the same problem with my RAV4 2011 and 3GS. Did you solve your problem?
Thanks for a reply
Geo
