Help Needed Please!
jodiecam
Hi all,
I'm new to here and hoping someone could help me please?
My 1995 Celica 2.0l has decided recently to become very hard on petrol, would anybody be able to tell me where to start ruling out problems??
Many thanks in advance
Lisa
It's got cold so it will take longer to warm up.
Seviced lately? Booting it a bit harder?
How many miles has the Air Filter done?, many owners don't bother replacing on an old car. It would be worth checking the Plugs too. It's also possible you have a sticking Brake Caliper, so check all four Wheels are spinning freely.
While you're at all four corners, have you checked the tyre pressures recently?, they will drop as the outside temperature reduces and increase drag.
As Bryan says, the car will be running on automatic choke longer in Winter, but that should only make a small difference in MPG.
i got the car serviced last week made know diff getting about 22 till a gallon
Hi Lisa,
What was included/changed in the service?
Taff
22 MPG, now that's not good !!! How are you checking the consumption, full tank to full tank?
Do you do any long journeys in it or is it all short trips?
I'm sure other ST202 owners will confirm midd 30's is the more expected return.
OK does it rev freely upto the redline when warm?
hi all sorry it took so long to reply it got oil filter,air filter,fuel filter and plugs i have just replaced the cat as i felt the car was not reving clean [when accelerating the car felt like holding back before going] but still know joy please can anyone help as it is costing a fortune to run
the car is still the same when accelerating the car feels like its holding back before going
is there a differance in gearboxs as it seems to rev hi when driving [60mph at 3000rpm]
thank for your time
OK back to square one as they say.
Did you used to get good Mpg from it?
3S-GE or 3S-FE?
Std size Wheels and Tyres?
All brakes free from binding? Do any of the wheels feel hot after a run?
3S-GE or 3S-FE?
It's a 3S-GE with standard size wheels and the brakes are free.
The car is now only doing 22mpg, what was it doing a few months prior? and has anything changed in your drive style like a new job to commute, also take into account of the denser traffic due to the xmas shoppers and the lower ambient air temp
The reason I say this is because my brand new works Discovery averages 25mpg but has now decreased to 21ish from the cold and more traffic due to xmas shoppers, even dropped to 19.8mpg on Saturday,
