Bleeding Clutch
Vlado P.
hi,
i wish to replace the brake fluid in my 2005 avensis 2.0 vvt-i (1AZ-FSE) with some high quality fluid such as ATE Racing Blue. Bleeding the brake lines is no problem, however since the clutch shares the fluid reservoir with the brake system, I would like to bleed the clutch system as well, for two reasons:
1. the brake fluid is 6 years old and I am noticing reduced brake performance
2. i don't want to have mixing of the old and new brake fluids which will lead to reduced performance of my new fluid.
so my question here is, whether there is a way to bleed the clutch system? i can see that other models have a bleed plug on the clutch slave cylinder, however as far as i can tell from the schematics, 1AZ-FSE types do not have such plug.
any help is greatly appreciated!
thanks!
