I changed my oil on my rev3 turbo this weekend and as usual I got my oil and filter from Fensport.
It was the usual fully synthetic Valvoline oil that I get from them but this time it was 5w-50w oil. It says that it is for motorsport use.
Is this stuff ok?!
Cheers
Matt :thumbsup:
Should be ok mate if its listed with service parts, it had better be as my oil/filter is a couple of months due a change :ffs: therefore will be buying some!
TBH 5w is a little thin for the engine, you may find it sounds a bit rattly on startup - the noise should dissappear as the engine warms up and the oil reaches its 50w viscosity. I find the best oil grade to use is 15w 40.
