Auris T180 Spacesaver Wheel
englishgt45
Hi all
Has anyone ever been succesfull in finding a spacesaver wheel that fits an Auris T180 ?
If so, do you have a part number.
Many thanks
This topic has been done a few times, try the search next time.
But I bought this spec when i had the T180, it was fine:
T125/70 D17
Good luck.
Agree with T Sport.
I (along with others) posted on this a year or two back. All the info you need is there including part numbers for the rim.
From memory the rim came in around 50 quid and the tyre was about the same.
T125/70 D17
Good luck.
thanks for your help
They are about £150 inthe dealer but you can find a used one on eBay occasionally for £60-£90 depending on how lucky you are. The Avensis Spacesaver I think is the same but you had better check that one out or maybe someone knows on this forum. Try asking 'Parts King' on here for a price, maybe competetive.
Hi all
Many thanks
The space saver spare wheel for an 2006 civic onwards fits fine and with plenty of them on the roads this should be easier and cheaper to find
