Gear Selection Chirp
Nigebob Squarepants
Noise when putting it in!!!!!!! ooh er missus, keep it clean.
Noted recently that when I select 1st gear from neutral I get a slight chirp noise…
It occurs just as you feel the very slight resistance before it slides home…, this is the only way I can describe it.
I’am not particularly worried, but!
Mostly in the cold weather conditions.
Anybody got ideas? :unsure:
Yeh try a bit of WD40 under Yer Knob .................................... :rolleyes:
My auris squeeked going into first. Turned out the linkages had no oil. Mr T fixed this under warranty and it drove like new again...
So He put some oil round Yer Auris .................................................... :unsure: :unsure: :unsure:
You do not want to know what happened next... :eek:
You could well be right !!...
Cheers Guys!… Keep it well lubricated then! :thumbsup:
