Fault Codes On A 95 Rav
supraneil
I have done it before a long time ago but i am not 100% certain if am correct, do i bridge E1 and TE1 terminals?
Where is a list of what codes relate to what.
Thanks.
Neil.
Thanks.
Neil.
Correct with the terminals - E1 and TE1
Codes are basic but here you are;
Early models.pdf
Thank you for that, however i am seeing code 25 (tested it 3 times just to make sure) and i can't see that listed.
I would cancel that and see if it comes back. It could be somebody bump started it or something. It only needs to see the lean mix for a few seconds to record it.
I will clear it in the morning and try it.
Speaking to a lad on the supra forums who is a mechanic, he had a rav in last week with the same problems as i have and it turned out to be a split hose somewhere which could explain why its lean.
