Autis T180 Mpg
DazT180
Hi, i purhased my 57 plate T180 in september this year, in the last few weeks the mpg has dropped from 41 to around 35, doin the same style of driving and same journeys, could there be any reason as to why it has dropped so much?
The cold weather is probably causing the D-Cat system to be regenerating more frequently, thus using more fuel.
If you have a search in the Auris/Avensis/RAV4 forums you will find thread after thread on this subject. The 180's are a very complicated beast :thumbsup:
I know alot of people are cleaning the dpf out, is this a difficult job?
Your thinking EGR valve, have a search for RickD4D's guide, its a simple job. The D-Cat system sort of cleans the DPF ;)
Cleaned mine out but still only averages 30mpg.
Thats not good mpg at all. When were all the filters changed? What heavy oil you running her on?
EGR cleaned last month but air filter and service due now, thanks you just reminded me.
