Hi - the boot btton has got stuc again, had it replaced loads but normally lock/unlock makes it pop back out.
Today it won't pop back out....the car is in a secure garage but needs to be moved in a couple of hours. Any ideas on how I can get it to pop out again so I can close the boot properly?
Help!
Hi mate I have an 06 Aygo Plus and the same problem.
There is a little plastic cover behind the boot lock inside the boot, remove this and you can press the mechanism and the boot button should pop out fine.
I've left my cover off as the button sticks every now and then.
Hope this helps.
Regards Andy.
