Tow Bar Wiring
niksr
Hi, i am fitting a tow bar to my auris but want a cheaper way for wiring as the genuine
wiring kits are very pricey,would i be able to fit it the old way solder the wires
into the loom from the 12n socket to a audible relay,or should i buy a smart relay which just req
a live then this will make it safe ie multiplexing and can bus etc ideas would be great :rolleyes:
Change all trailer lamp bulbs with LEDs so that you won't need any relay, fit only an ordinary trailer socket directly connected to the car rear lamps harness.
