Hello New Rav D4D Owner
bluerav4
Well, .could have been a lot worse..................
What about the rocker cover?
  • Replies 108
  • Created
  • Last Reply
Top Posters In This Topic
  • bluerav4
    44
  • jedi134
    27
  • anchorman
    9
  • Tech01
    5
Posted Images
Was the rocker cover hole just the hole where the injector popped out?
I wonder who worked on the injectors previously? :D
So they told you you needed a new engine just as a wind up??............always a sign of a good garage that knows what there doing. :P
Yeah they did wind me up and wasn't amused.
No they've not mentioned rocker cover just a gasket. I'll double check tomorrow unless they were winding me up about that too
Just glad it isn't an engine. Think men find it amusing as women don't have a clue. I just can't wait to get it back
Is your car fixed yet? I think I'm getting similar symptoms as you have described. Was it the injector that caused all the damage?
Finally got my Rav back. It's unbelievable the difference. Drives as a Rav should. It's also gone quiet compared to before. Also replaced all filters etc as you all suggested. Took it for a real long drive and it's fantastic.
The problem was not the actual injector. The seal or washer was the culprit and it seems that's what started the chain of events.
I'd really like to say a big big thank you to everyone for your input and advice and must admit it was all your knowledge of the Rav that helped rectify the problem. It's so amazing that a little washer/seal could cause so many problems
Once again thanks to all of you
Hi, the engineer said the seal or washer started the problem. It was missing when they checked all injectors were fine. On precaution he replaced all washers seals and bolts do hopefully should be the end fingers crossed. If you read my posts I think I've described symptoms best I can and my advise would be if it's similar to my problems get it checked before it causes any further issues
Hope that helps and good luck
Sounds like they done a good job, replacing all the washers, obviously looked at all the injectors then....might be worth naming them, if they did a good job? :thumbsup:
I'll definately be using them again.
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
