Matte Black Toyota Emblem
corollat3sport
Hey guys,
i want to spray my front Toyota Badge matte black and i was wondering if anyone else has done this and can show me photo's and also how i should do it? :)
also how do you think it will look...good or bad lol
cheers guys
Hey guys,
i want to spray my front Toyota badge matte black and i was wondering if anyone else has done this and can show me photo's and also how i should do it? :)
cheers guys
Get a spare Badge off eBay, wash of any residues with `Fairy`, dry, spray, done.
Now you can change back in seconds if you don`t like it. :)
thanks for the quick response guys :)
my front Toyota Badge is gold :( hence why im going to spray it matte black or maybe satin black...i don't like the look of it at the moment and after i spray it, should look a lot better and if not im going to go "dangermooser style"....get a badgeless grille :D
so shall i just buy some spray and clean the Badge and just spray it over?
Not that I am an expert but I think for a half decent result you need to sand the Badge with a fine paper then use primer before spraying it the colour you want, it will have a better chance of taking than just spraying it. I think there are plenty of guides on the right way of doing it on tinternet
Need to sand it with 800 grit, then primer, then a quick wet sand with 1200 grit, a coat of colour and finnaly laqure.
Just a pointer, dont use "matt black" paint. Its a nightmare at picking up and showing dirt and the finish will go horrible after a while and will require re-doing in no time, especially on a everyday car.
I use satin black, its soo much better and much more durable. Simoniz does an awsum spray can of it which can be had very cheeply of eBay. I personally spend a little bit extra and get the "tough satin black" spray they do, as it is a lot harder paint so less likely to chip (ive tried both) and is perfect for the front of a car.
HTH
awesome guys, now i know what to do so i will have a go at it :)
will be here if i need any more help laugh.gif as im not really good with painting so wish me best of luck
Just remember a good finish is 90% prep and that it will never be a "perfect job" from a rattle can and youll be fine :thumbsup:
Also dont spray the can to close you want to dust it on and build it up to a wet look, stop there as any more and you risk getting runs. My TTE spoiler came out as good as toyota painted the car itself ;)
thanks for everything guys, i thought it was just taking the Badge off and spraying it and putting it back on laugh.gif
now i know my Badge will look perfect :)
thanks again
i think it will be easier for me if i can take it off :)
anyone know how to?
also i have found this Steven:
http://www.ebay.co.uk/itm/290594927332?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649#ht_1748wt_952
good or avoid?
cheers guys
@dangermooser
anything new with the rolla? haven't really seen a update on your thread recently lol
anyone know how to?
good or avoid?
cheers guys
@dangermooser
Yup that stuff is good, but i'd personally spend £2 extra and get there tough spray as its less likely to stone chip. Dont forget you need to get some primer too ;)
http://item.mobileweb.ebay.co.uk/viewitem?itemId=160646929988&index=2&nav=SEARCH&nid=92863863473
If the Badge is like the E11 all you have to do is remove the grill (two screws) and its clipped in from behind, just push the clips in and volia itll pop out.
If you take of the black panel around the bonnet latchvyou can unclip the Badge, but if you cant do that then unclipping the grill is just as easy.
@dangermooser
Yeh have done a few more bits and pieces including updated ice, CAI and other bits done and in planning!
Generally don't post much on here nowadays preferring the dark side of the site that must not be mentioned
anyone know how to?
http://www.ebay.co.u...9#ht_1748wt_952
good or avoid?
cheers guys
@dangermooser
http://item.mobilewe...nid=92863863473
oh sorry i forgot to look for the extra tough paint lol thanks for that mate almost forgot haha
sorry to hassle you but can you point me in the right direction of some good primer i should use?
cheers mate
If you take of the black panel around the bonnet latchvyou can unclip the badge, but if you cant do that then unclipping the grill is just as easy.
i sprayed my front badge black imo looks much better :thumbsup:
@dangermooser
oh right lol well best of luck though mate :)
cheers mate
I again personally use the simoniz white primer - avalible from the same guy on eBay too, so combine the two for cheeper postage ;) but any primer will do :)
cheers mate
Hmmmm no im going to go your way and use the simoniz white primer then :) and also see if i can save and get cheaper postage laugh.gif
SAM_0460-1.jpg not a great pic sanded it back removed the silver for a good key, primed it and matt blacked it
