Fitting Mudfalps To A Rav4.2
Molnboman
Hej Hej Boys and Grls!
Nice day today and decided to fit the Original part Rav4.2 mudflaps....all went well apart from nearly doing a great impression of the "Angry Man" :censor: trying to get the grommet to fit into the bottom of the nearside front flap....there's no way it's goin in!...the grommet appears too short to me!....All three screws match and fit snuggly except that bottom grommet! The offside was not a problem and managed the bottom grommet in easy peasy....just wondering if it's me...or has anyone else had this issue?...Will it be ok with just the three wheel arch screws without the grommet at the bottom? Whadya reckon?
Thanks in advance and stay warm!
Cheers
A
Whilst it should be OK without it I would still want it in place.. If its a little tight why not measure the grommet and run a drill bit through the hole to make sure its clear ?? I had no issues at all with My ones.. HTH...... :thumbsup:
Thanks Charlie....it's just too flippin short...and it seems not big enough to fit it in the hole...fnrrr fnrrrr.....I tried the grommet on it's own in the hole and it's fine...but by the time I put it through the whole in the mudflap it a bit smaller and too neat to "open up" in the hole!...Maybe a longer, bigger grommet is the answer...but will Mr T's spare parts guys just think am a tool!...answers on a postcard please! hahaha
Shame, cause all the offer ones fit grand on the old tank!
A
A
Have you tried swapping the one from the other side to check?
EDIT
Are you meaning a square plastic expanding plug that goes into the underbody?
If so this should go in to the hole in the underbody first with the mudflap over it and the screw then inserted throught the hole in the mudflap lug into the expanding plug.........
Edited by Davrav
Have you got a photo?
Right....that would explain it!....I thought it was just the grommet! :blink:
Was wondering what the extra screws were for!....I am a donut!
That's why I need you clever Dudes and why I need this Forum! ...Doh!
Many Thanks....
A
Well this shows a bit about how the 4.3 mudflaps fit;
http://www.toyotaownersclub.com/forums/index.php?showtopic=107687&view=findpost&p=981359
I don't have the instructions for 4.2s but after fitting that captive nut insert you just send the supplied screw into it. I wonder who has got my blue one now???
Very grateful for all the advice...Sorted the buggers out this morning in 5 minutes!..Many thanks again....only niggle is at the rear mudflaps.. the top screws are turning ( no thread to grip )...what should I use to keep those in..Blue tak/bit of the Wife's old wedding dress/ super glue?
Cheers
A
Cheers
A
You need a couple of these:
Beat me to it Dave. This fella will get on your nerves "OK" but if you look about 5 minutes into the clip you can see a similar fixing being used;
You prepping Charlie?
Having watched the clip I'm surprised he finished the job with with all fingers intact :eek:
Well after seeing that clip i will attempt the MFs on our Rav :thumbsup:
Do those clips/fixings come with the new MF kit??
If you're getting a genuine set it should come complete with all necessary fixings and clear instructions Paul :thumbsup:
The instructions for fitting rears to tha 4.3 show to remove the wheels which I'm sure makes the job easier but I managed mine without doing so - just a bit more fiddly.
Front wheels can simply be turned left/right as required.
If you getting a genuine set it should come complete with all necessary fixings and clear instructions Paul :thumbsup:
Thats great thanks Dave :thumbsup:
I've just sent Kingo a PM re MFs and sidesteps :thumbsup:
Hej, yes they were an original Toyota set, however, you only get new fasteners (2) for the bottom of the rear gaurds....nothing else!
Cheers
A
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
