Since Toyota found it cheaper to not put a tach in a car with a 5-speed, I thought I'd like to add one. I had a couple of ideas. Maybe find one in a junkyard? if so are there any connections for it under the dash? Or, add an aftermarket tach. I figure someone must had added one as I know it drives me nuts not having one. Where have people mounted them? I appreciate any suggestions.
Denny
literally any tach can be added as long as you get the engine speed pulse wire for it to sense
Hi denny im in the same boat as you!
Jaxx yes I know that but does the corolla (mine is a 1998) actually have the wire?? Because then I could just go to a scrap yard and pick up a new dial kit which has a tachomater.
Yeah, that is what I was wondering as well. I still can't believe someone would build a car with a stick with no tach. Must have saved them $10
