This 4.2 Egr Valve.....
rambler
Right......on my way out to for a lovely days walking :D
Got out of village,onto main road....put my foot to floor (in a rush),engine temp gauge 1/4 of way up,then......engine held back quite badly....then
That engine light came on,went into limp mode :o so i pulled over (lucky i found a lane to pull into).let it all calm down,turned off,jumped out,locked it and waited a few mins.
Then unlocked it,started it.....engine light didn't come on this time,drove normally :blink:
Went for a further good strong drive around quiet country lanes ( bit of thrash around)...no troubles ( bearing in mind engine in full operating temp now)
Now......the fault occured during engine warm up ( temp gauge 1/4 way up),now engine at normal temp....all is well :wacko:
I have to admit it has held back a little for ages now ( during gentle acceleration),and at same stage of the day ( during warm up) ..but once normal temp is reached it appears to be ok.
Now i've had the DMF done,SCV''s done....would the EGR cause this ?:help:
Have printed off the item from the pinned section,as tempted to have a go myself,but think i will leave it to garage.
Rav booked in at nearest garage for Thurs pm,only time i have off work
Well.....just taken Rav for a quick run around,IF i just start it as i always do...give it a min or so before actually drive off,then gently pull away through the gears barely go above 4000rpm.
I must just resist flooring it ( have never ever red lined it anyway)...until its reached full normal temp.Even then i've never redline'd it.
If i need to pull away from a busy junction....i can't..... if its still warming up
Once it's at normal temp....it goes ok.
Still need that fault code though :thumbsup:
