Help Needed
AJ1975
Hi All,
I just signed up today so my very first post on this site. Just wanted some advice in general. I currently have a Passat 170 Sport Diesel. I have problems galore with this car ranging from all 4 injectors to Needing new DPF so am Looking to buy a Avensis but not sure which model to chose. Lots of people recommend T180 but some saying it has issues and then there is dreaded D-CAT (Another name for DPF monster) I could really do with some help and advice. I need a Saloon preferably DIESEL (2.2 better) Will be doing 10-15K miles per year and looking to spend around 5 - 5.5K. I have seen a lot of Cars around 70-100K miles on the clock but not sure which version is the best Please your help as it will be much appreciated. I am just Fed up with spending money on my Passat forever
Thanx in advance for your valuable advice :
Hello and welcome! Sorry to hear about your issues with your passat. What is your average mpg with the passat at the moment?
I am getting 40 MPG in Town and Motorway is 50MPG.
advise MPG wise, expect 30's in Town and 40's on the motorway with the T180.
Get a 2.0 litre Petrol Avensis, cheaper to buy, cheaper to maintain. Yes the MPG is worse but 10-15k per annum isn't enough to warrant a Diesel.
I've heard that the Passst suffers from the same problem with the Audi (Same engine) does regarding the injectors and my mate has had a re-call and had 4 new ones under warranty. The Avensis 2.2 T-180 is a lovely car to drive but the mpg is nowhere like what it should be unless you bolt on a tuning (48.9mpg @70mph) piggy-back box! Toyota does have problems (Like most marques) with the EGR valve/DPF (D-CAT) and head gasket issues on the oil burners. But the good news is that Mr T has a pro active approach and covered this issue with a 7 year 112k extended warranty. I find that running V-Power derv helps to maintain the EGR and the car runs better for it. Some also use a fuel additive to.
The T-180 gives you all the toys like sat nav and leather electric seats ect and like all the Avensis models comes with 9 air bags (2 knee) as standard. The brakes are awful so are the headlights, thats why a few of us have changed the original Bosch set up to discs and pads from MTEC which now does the job.
Hope this helps :thumbsup:
your budget means a T25 (old model up to end of 2008) or a very high mileage T27 (Jan 2009 on).
For the mileage that you are doing I'm with cabcurtains & would suggest petrol as modern diesels are complicated & therefore often expensive to fix when they go wrong (I know that you've discovered this with VW) - turbos, high pressure injection DPF, DMF etc. etc.
Alternatively if you get a non-T180 2.2 D4D then it has no DPF & you should get at least 5mpg better fuel consumption than the T180. I'm biased no-doubt but if you don't care about leather seats then imo the T25 facelift TR trim level is great value for money - most of the toys for less money. -
I would like to think this would run and run if looked after 2.0 T-Spirit with 12mth Warranty looks like a lot of car IMO.
That does look like a nice motor an all mate. So do some of the other that they have on the pitch. And there is room for some cash off an all I recon :thumbsup:
