Engine Warning Light Help
jps71
Hi Guys
I know this may have been covered elsewhere but can not find any info.
I have a 2001 4.2 D4D Rav.
Yesterday I was accelerating up hill over taking a slow car.
Suddenly I had a complete loss of power and the engine warning light came on.
I managed to get the Rav to the side of the road left it for a few minutes and then restarted it.
Every thing was fine and I drove the 40 miles home with out missing a beat, the only problem being that the engine warning light stayed on.
This morning I gave it another try after having read somewhere that the light might have gone off of its own accord.
I started the engine but the light is still on.
It does not appear to be having any effect on the Rav it accelerates fine with no loss of power.
Does anyone have any suggestions as to what the problem/cure might be?
Cheers Jim
Hi Guys
Cheers Jim
Hi Jim, there are more qualified people on the forum to answer this like 'anchorman'...etc but the same thing happened to me (2004 D4D) a couple of weeks ago and like you I continued my journey with no probs at all? After reading advice on here, the next day I took the negative lead off the Battery for a minute to get rid of the 'check engine' light and the car has drove sweet since (touch wood) Now It has been advised not to jump at any sort of problem like SCV's etc and to get an engine code number to point you in the right direction!
Hope this helps (for now anyway)
Steve
Thanks for the info Steve :)
I will give it a try tomorrow.
Cheers Jim
yes please state the code explanation first.
cheers/Igor
Thanks for the info it worked a treat :)
Igor sorry I don't have any code info it is a 2001 so code readers don't work on it :(
Cheers Jim
Cheers Jim
ok JIM
what do we have now -- only yr explanations/observations to start to think?
just advise whether or not the first post matters are an actual.
cheers/Igor
If you mean is what I said in the original acurate Igor.
Then yes it is.
is engine urbocharged or not ?
cheers
Then yes it is.
cheers
Yes it is the 2ltr Diesel D4D
firstly check with resistance of SCV; clean contacts of turbo pressure sensor; clean an impulse tube for the same;
thanks to no power loss was observated after then you have possible control signal casual loss. also -- check with draining ***** from fuel filter -- whether or not water is in diesel available. check and revert/cheers
