Engine Rattle
Sabre46
:thumbsup: Ive got a 98 RAv4 2ltr Petrol. Ive started getting a rattle from the right hand side of the engine bay (when sat in the car). It sort of sounds as if there is a loose component on the exhaust but goes away over 1800 revs. Could this be a timing chain issue. The car has done 119k miles. :help: Many thanks.
Hi Stuart,try putting your post in the RAV4 forum,your sure to get advice from others who have this model.
Good luck.
Had engine rattle when shifting (manual trans) and accelerating between 1500-2000 rpm range. Seemed to be relieved when the clutch was momentarily pumped. Well, had the clutch replaced today due to genuine clutch problems (squealing sounds, friction sounds, etc).
