Oil Sump On 2006 Hilux
05hilux
is it possible to remove the oil sump on a 2006 2.5D4D hilux without having to remove engine. Original sump has rusted through an is leaking engine oil.
Rusted through in 6 yrs, is there a particular reason for that one to rust so bad in 6 yrs its leaking ? :eek:
Hilux was first registered in the UK,where it did alot of motorway miles
the road salt may have caused the excessive rust on the sump.
  • 3 years later...
i have exactly the same issue with a 2006 hilux d4d 2.5
Seems like you can't find a sump anywhere apart from toyota.
Anyone changed one and know how much has to come out and how long a job it is?
  • 1 year later...
Mine is a 2008 ordered a replacement sump from an off road specialist, garage wants £380 labour to fit it.
If it is 4x2 it's easy to remove. But if it is 4x4 i've ead that you have to pull the engine out or drop all the front axle... quite a job...
