Rear Nside Light Cluster Unit
nmarriott
Unfortunately had a minor mishap with my 2010 Avensis, which resulted in the rear cluster light unit, that slots into the rear quarter / side panel being damaged.
I have obtained a replacement part but cant figure out how to remove the curent part - would be grateful for all / any advice.
Thanks for your time & help in advance
Neil
Hi Neil and welcome to TOC.If you post your question on the Avensis forum i am sure you will get the advice your after.
Welcome to TOC Neil I think you need to post this in Avensis section.Welcome aboard!
