Rear Wiper Blade Replacement
fortywinks
Does anyone know how to remove the rear wiper blade from the rear wiper arm on an Auris SR 2009?
Hi Karen and welcome to TOC :thumbsup:
If its like my Avensis it should just clip off. It might me different to mine so someone should be along who has done this on a Auris...
I too have a problem on my Auris a 1600 V-Matic. Having been sold a replacement rubber by my Toyota dealership how do I remove the old rubber and relace with the new one. I shall be grateful if any Auris owners can help with this..
It's not easy, but it could be done. You need to flip one end of the blade out and then pull out. The metal holders are pretty flexible and I have't broke them yet. You should use some lubricant to lube the rubber when sliding out, and the new blade going in. Soap and water will do fine. You could even do the sliding part in some container filled with soapy water. If you do this without any lubricant you would probably torn the new blade (the old blade too, but who cares ;) )
That must be completly easy for you....just do a visual check and see how it clicks or attach to the wiper arm
