Drive Shaft Gaiter How Do U Fit One
help need some info took drive shaft out how do i remove cv joint
Hi, would it not be first a good idea to buy a Haynes workshop manual from your local Halfords shop as you really need photo descriptions to guide you rather than just guiding you with words!
got gaiter on just had to clean cv joint up [remove all the grease] and then clamped drive shaft in work mate and gave cv joint two good hits using alump of wood as a drift and it came off .who needs a manual. thanks any way
