Electric Window Switch
nisnote
the auto part of the window switch has stopped working and the switch is flashing now.anyone know of the fix?
Short answer is no :)
A few possibilities.
It might be genuinely faulty, or it could be due to water ingress somewhere however before looking into any of that as with anything electronic do a "reset" by disconnecting the Battery negative terminal, then with it still disconnected press the brake pedal for a few seconds (to allow the bulbs to apply a "short" across the supply). Wait 5 minutes and reconnect Battery smartly and cleanly, no dithering.
Retest windows. If the one touch doesn't work reset it by pressing and holding the switch for at least 20 seconds to wind fully down and then do the same to wind fully up.
Good luck... if that doesn't work then it sounds like a real fault somewhere.
