Engine Vibration 2.2 D4D Avensis
avensisrob
Hello all
Has anyone experianced issus with engine vibration?
I have an 07 2.2 D4D tourer with 30,000 miles , It has just had its anual service and it has come back with a large amount of engine vibration when it is ideling. It dissapers when the engine is reved up but was never this rough before.
I am at a loss to thing what has been done on an intermediate service that could have caused ths and there is no obveous parts haning off.
It booked to go back into the dealer but if there were some common falts I could have them look at it might just save me from a heave investigation charge
Rob
it is instable performance of an injectors -- creating an overfueling effect in each cylinder. unburnt diesel in the close cyls starts to brake rotation. cheers/Igor
If the problem has occured after it has been serviced than you should ask the ones that serviced it. They must have done something to it, maybe swap some of your parts with other deffective ones.
Thanks both
It is going back to the main dealer end of the week (also where it was surviced) but its better to have an idea about what it might be before hand.
Thanks for you help
I will post the outcome
Rob
  • 2 months later...
