Temperature Switch Odd Noise!
Kryten
Hi, now I may just be paranoid, having just given someone a jump-start, but when pushing the "TEMP" button for the heating, I can hear a sound like a motor or servo operating which corresponds to each push of the button, up or down.
I don't recall ever hearing this before today!
Can anyone shed some light on this?
Does something require resetting?
Thanks for taking the time out to read my post.
Got me mate!....... Have you tried to disconnect the Battery for 10 mins to see if the system re-sets?
Thanks for getting back to me so soon. I haven't tried that yet but it is obviously an option.
Just so everyone's clear, I connected the leads in the correct order and connected the neg. lead to a large engine bolt (not the neg. Battery terminal) on the car to be started, last. This I am assured, is the correct way to do it.
I had wondered if you'd maybe put the leads on the wrong +/- for a moment! Hope the reset sorts it...
It does sound like a servo motor that controls the air mix damper. You can try running the AC diagnostic. Here's the procedure on the RAV4:
CHECK MODE PROCEDURE
1. PANEL DIAGNOSIS (INDICATOR CHECK)
(a) Turn the ignition switch to LOCK.
(b) Turn the ignition switch ON while simultaneously
pressing the A/C control AUTO switch and the REC/
FRS switch.
{c} Check that all indicators and the display area are
turned on and off 4 times in succession at 1 second
intervals.
HINT:
After the indicator check is completed, the system
automatically enters sensor check mode.
(d) Press the OFF switch to terminate the panel
diagnosis.
2. PANEL DIAGNOSIS (SENSOR CHECK)
(a) Perform the indicator check.
HINT:
(b) Press the REC/FRS switch to enter actuator check
mode.
{c} After the actuator check is completed, press the
AUTO switch to enter sensor check mode.
NOTICE:
The sensor check must be performed again after
the actuator check is completed because sensor
check mode, which starts automatically after the
indicator check, cannot fully detect
malfunctions.
(d) Check the sensor check results displayed on the set
temperature display.
HINT:
• The illustration shows the display when code 21
is output.
• When 2 or more sensor check codes are
detected, the codes are displayed in ascending
numerical order.
• In cases with 2 or more codes, if they are difficult
to read, press the DEF switch to activate the step
operation and display them one by one.
• The codes are displayed in ascending numerical
order as the DEF switch is pressed.
(e) When any sensor check codes are displayed, refer
to the DTC chart (see page AC-39).
(f) Press the OFF switch to terminate the panel
diagnosis.
HINT:
Pressing the REC/FRS switch returns the system to
actuator check mode.
3. PANEL DIAGNOSIS (CLEAR SENSOR CHECK CODE)
(a) Inspect, and repair or replace the malfunctioning
parts.
(b) Clear the sensor check codes.
(1) While pressing the DEF switch during sensor
check mode, press the Rr DEF switch.
HINT:
Sensor check codes can be cleared by removing
the ECU-B2 fuse from the engine room No. 2
relay block for more than 60 seconds.
{c} Perform the sensor check and confirm that normal
code 00 is displayed.
4. PANEL DIAGNOSIS (ACTUATOR CHECK)
(a) Start the engine and warm it up.
(b) Perform the indicator check.
{c} When the sensor check is started after the indicator
check, press the REC/FRS switch to start the
actuator check.
HINT:
Perform the actuator check with the engine running.
(d) Check the temperature and blower levels by hand at
each step while the actuator check proceeds from
step 0 to 9 at 1 second intervals (continuous
operation).
HINT:
Each step number is displayed on the set
(e) To display step numbers one by one manually,
press the DEF switch to activate the step operation.
The step number changes each time the DEF
switch is pressed.
HINT:
• Each step number blinks at 1 second intervals
during the step operation.
• The illustration shows the display when step
number 5 is displayed.
diagnosis.
HINT:
Pressing the AUTO switch returns to sensor check
mode.
Thank you, phew! That's a lot of information to take in.
Would the fault show up on OBD reader, or is that strictly for engine diagnostics only?
No, any codes that show up will be on the temperature display only.
Okay, thank you.
Battery disconnected at the moment, will re-connect this afternoon and update here to report if anything has changed, otherwise I guess it's off to Mr. T. to see what they have to say about it I suppose.
Okay, Battery now reconnected. It seems that the motor/servo sound has gone, except now, when I get to "LOW" (the last setting down from 16 degrees) there is a sound like a flap closing!
