87/88 Celica
Phreaq
Hello NG,
HELP !!
I have a power failure on my Toyota Celica 1987/88 model 2.0 GT Auto lhd, and it appears to be the power that goes to the Fuel Pump is no longer there,
Can anyone please tell me where the relay or fuse for this fuel pump is in
situ on the car,
Tested all fuses I could see, Battery is fine too, also in case im asked there is plenty of fuel in the tank, I do not have a manual so I dont no where all the relays are for the power to the fuel pump, under the hood I found the fuse boxes, however they are not clearly marked.
I have also tested with an avo meter at the plug socket under the seat that feeds the fuel pump, it almost seems like there is a short somewhere as I am not getting a reading of power from this place.
I cannot find any discription that relates to a fuel pump relay, I only see "EFI relay" this is a most unusual problem and I am now at a loss of where to look.
Any help greatley
recieved.......
Regards...
Kev........
