Headlight Bulb Change 99 Avensis
Graeme
Can anyone out there give some help - surely this is an easy job - just want some tips and advice on the best way to do it
pull off the black rubber circular cover(3inch diameter( , unplug the connector off bulb. unclip spring retainer. note how bulb sits, and pull out bulb.
insert new bulb not touching the glass. make sure it sits flat with the tab up top. ( i didnt and wondered y my aim was ****.)
put spring clip back over. plug bulb in. test. pop rubber cap back on. close bonnet :-)
