Avensis 1.8 Gls 1999 Coolant Leak
adecbr929
Hi There
Have noticed a coolant leak coming from the top hose connector (The cast part) which is bolted to the head with 2 bolts & then the coolant hose attaches to this.
My question is if i remove this connector is there a gasket behind this which i need to order or because i can see crusty white residue visible on the front of this connector is it possible this may have a small fracture in it (Not sure if this is a common thing).
Cheers
Ade
Hi Ade,
I have checked where I can (Haynes manual etc), and I would assume a gasket would be used and needed. Check with a Toyota dealer to confirm.
Otherwise you could get a universal gasket where you cut the shape you need.
The other option is sealant.
A fracture is rare but possible.
Are the bolts tight enough - they may have loosened.
I think you are on the right track.
:thumbsup:
Hi There
Many thanks for taking the time to check in your manual,i have got a new part from Toyota & will fit this today.Turns out this union has its own seal which may have perished.
Many thanks
Ade
