56 Avensis 2.0 D4D Wont Start
speedemon
This morning went to start the car and as i turn the key the instrument lights came on and as the engine was about to turn over all the lights of the instrument panel went off and a strsnge noise came from tge engine.
hi
what kind of noise has been disclosed ?? as you can understand wee are all read it even false sometimes.
be more accurate and revert.
cheers/Igor
Sorry i wrote this with a hot head and englis is not my first laguage.
The noise it makes its not the engine turning over its like a krrrrrrrrrrrr but very low and its coming from near the fuse box in the engine. Also i taped on top of one of the fuses and the istrument lights came back on after i tried to start the car and it all died again dont know if it is the batery or an electrical probem. The batery is the original 6 years or so old what i find strange is the car alwais started on first try whith no problems .
Thank you for your help in advance
it looks like the Battery has died at all -- this krrrrr noise looks like relay noise when very slow el signal comes from alternator.
check with density of Battery acid -- but be ready for worse cos 6 years is due. normally 3-5 years is OK. besides just to be sure check with charging current/voltage coming fromo an alternator/rgrds
