Head Gaskey 98 1.8 Petrol Carina.
Stephen Lewis Whale
Ive recently had trouble with my 1998 1.8 petrol carina. I m hoping to find someone with an engine they'd like to sell- preferably with fairly low milage and serviced regularly. I ve been told that the avensis engines are compatible as well.
i ll check this forum tomorrow to see if there is any advice on this problem. ive been quoted 500euro to replace the head gasket. Does this seem right?
steve in galway
Hi Stephen and welcome to the TOC.
For advice on your Carina problem try the Carina forum where others have the same model as you.
Good luck.
Hello and welcome to the TOC Stephen,
As ^^Peter^^ said, post your question up in the Carina section, and I'm sure someone will help you out ok :)
