Help - Dipped Headlights Not Working!
Deborah Charles
Can anyone 'throw light' on this for me ? My side lights, fog lights and main beam are all working, but no go with dipped lights. Is this a common problem and any suggestions on the remedy please.....
Both bulbs gone?
Not sure if dipped beams run on a seperate fuse. If they are, that might be the reason.
You need to check the lamps first, if they are OK check the fuses.
It might help if you let us know what Gen you have and your location
