Rattling Noise From Rear Passenger Door
PADDYLAD
Wonder if anyone can help.
I seem to have aquired a rattling noise as I drive along. It sounds like the door is rattling around in the door frame. I have checked the seal and nothing seems out of place and have rubbed a little WD40 on the seal both on the door and in the frame incase the seal had dried out in the cold weather.
The front passenger door is staring to do the same and so is the drivers door.
Has anyone experienced the same problem and how did they sort it out or is it just a case of taking it back to the dealer and have new seals fitted. I presume with all three starting to do it, it must be something to do with the cold weather and the rubber shrinking.
can't say I've experienced this with the colder weather, sounds like a dealer visit may be needed. Let us know how you get on if you do go!
