Tns510 Bluetooth Mic. Level
Ludovic
I have a TNS510 in my Auris HSD
Do you know how to change the level for the on board microphone (used by the bluetooth freehand) ?
I remember reading that you can access the "service menu" and change a value there, but I can't find how to do this anymore...
Has anyone done this ? Did it improve the mic. level ?
Thanks,
Ludovic
On the Prius it's ign on, READY or ACC mode, hold INFO-TEL button and turn headlamps on and off 3 times to access service mode. Don't know if the same works on the Auris though.
OK, I found how to do that, it's pretty much how you describe it:
While on READY or ACC: select and hold the MENU key, and turn headlamps on and off 3 times.
Then at the bottom of the screen there's a bluetooth menu (can't remember the exact wording).
Then there's a "Receive voice level" value, which I increased from 0 to 3
I have to make further tests as the person I called for the initial test said "it might be slightly better"...
Thanks,
Ludovic
