Problem With Remote Key Not Working
Luthier
I have a 2 litre D4D 2008 Avensis with the usual 3 button remote key. The problem I have is related to one of the 2 keys I have. One works fine and the other usually works ok but recently on 3 occasions, the remote has failed to unlock the doors. I also noticed that when it doesn't unlock the doors the little red led does not light which to my mind indicates the problem lies with the key itself. I have changed the Battery and when it does work it will unlock the car from 20-30 metres away. When it first happened I thought never mind I'll use the key manually. Unfortunately this sets off the alarm!
Is there a way of unsetting the alarm manually?
Also - am I able to replace the electronic 'box' within the key as it seems this may be the source of the problem. Any help would be much appreciated.
most likely the micro switch inside is broken {common fault}
I had similar problems and fitted new microswitches to it. No problems since. Have a search on eBay for the switches. A bit fiddly to replace, you will need a small needlepoint soldering iron and probably a magnifying glass.
Sorry for the late reply and thanks to both of you for the info.
Interestingly I started using my spare key (which had never been used since the car was new) and within a week I had the same problem! I discussed it with my Toyota dealer who suggested that it may be that I also have a computer memory stick and small torch on my key ring. When I sit down at home or at work, the memory stick or torch presses on the buttons and the key turns itself off after a while. If I then go to the car and try it, the remote will not work. So two weeks ago I removed them from the key ring and so far there's not been a repeat of the problem! Fingers crossed that it's so simple.
