Handbrake Adjustment 2003 D4D
Glasswarrior
Hi, I don't have a manual for my car & Haynes don't seem to produce one. I want to adjust my handbrake before the car goes for next MOT. Can someone tell me the procedure for this car? 2003 D4D T Spirit saloon.
TIA
Cheers
remove the wheel and you will see a rubber bung on the hub part of the disk,remove this and put the hole in the 6 oclock position and look inside you'll see a wee cog turn this till you can feel a slight drag on the disk...
  • 2 months later...
Sorry took so long getting back, I'm not on here often. This worked spot on, thank you.
What is the procedure for the the handbrake lever adjustment as mine is almost through the roof ! Is it as simple as releasing the lever and tightening the nuts that holds the cable on ?
Thanks in adnance,
Nick.
