what power steering fluid should i use for a 96 previa auto? the cap says Dextron type atf but i cant find that in Halfords. Is there an alternative that will mix with what is in there at the moment, which i assume is dextron type atf.
thanks dazza
Go onto Opie Oils web site and it will tell you what you need! Or any of the major oil companies have lube recommendation finders...
  • 2 years later...
There is one available at Amazon. It's the Castrol brand
