Corolla Ae111 4A-Fe Engine
mohd jais
I have a corolla 4A-FE engine, during cold engine the auto choke is not functioning. once the engine is warm, the auto choke is functioning
Anyone know which part is faulty.
Hi Mohd and welcome to the TOC. Try putting your question on the Corolla forum for the best results.
Good luck.
The 4e-fe engine does not have a choke - it has a cold start injector that is controlled by the ECU. When it's cold the cold start injector is activated and more fuel is put into the engine. When the engine is warm the cold start injector is turned off by the ecu.
