Dash Lights Not Dimming
Yaris boy 40
My dash light are not dimming when headlights switched on any idea were the fault lies
Check the dash dimmer control. If it is turned all the way up, it's locked in at full brightness.
There's a button on each side of the instrument cluster. If you switch on your lights then push and hold the right hand button the display lighting will alternate between bright and dim (I think it's the right side button to adjust this!). Release the button when it's dim, Hopefully that will sort the problem.
Thanks for your help, it is the right hand button, for future reference, it needs to be on odo not trip
Thanks for this. I've been after changing the other way as I've been driving in quite a bit of fog recently and struggle to read the speedo with the headlights on.
" it needs to be on odo not trip" I forgot that bit! It's been a few months since I did it.
