Rhd Fusebox For Cig Lighter - I Must Be Thick Or Blind
bugbladderbeast
Ok read other people's posts as to where the fuse box is on the passenger's side of RHD Auris...I've looked, and looked but must be thick cos I can't see it!!!
Would any kind person put up a photo or two...driving me barmy and I need to change the fuse for the cig lighter.
Just to repeat...fuse box UK RHD not LHD.
Many thanks
You need to lay down on the passenger footwell on your back look under the glove box and you will find a large black cover with 3 clips on it remove this and you will find the fuse box it has a picture on it of the fuses you will need a pair of needle nose pliers to remove and install the fuses
Hope this helps
Hope this helps
Thanks....had a good look....still not seeing it...can anyone manage a photo??
Had a similar problem - had the car two weeks cigarette lighter wasn't working - took the car back and the Dealer couldn't find the fuse box first time - I phone local Toyota Dealer and they advised it is there but it is only small - Have another look and see if you can see something the size of two cigarette boxes
