Induction Kit ?
tabz
hi, newbie alert so my apologies if this has already been covered (still learning my way around) ..
looking at induction kits and noticing the price varies alot between brands, but noticed these on eBay and wondered if anyone has bought one ? and if they are "too cheap"
http://www.ebay.co.uk/itm/220862623258?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2648#ht_1119wt_952
You need to be careful with some eBay kits, as the MAF sensor mounting is the wrong way round.
Why do you want an induction kit? Noise? Power?
You best option is a good performance panel filter. There is a much reduced level of heat soak than in induction kit and you will get some noise.
You will NOT get a performance increase from a cheap induction kit. The only way you will is to spend big money on a complete shielded kit. Even then it will only be 1-3HP if that. A panel filter is more likely to give you some small gains, 1-2HP.
thanks for the detailed reply, can you recommend a panel filter ? .. thanks again
