Flapping Accelerator Pedal
Thrawn60
Hey again...
Another question :)
I was cruising a long the high way, and was getting tired in the foot, so shifted position, and noticed that my accelerator pedal can flab from side to side, a bit similar to it being loose, since I believe that the pedals in the Prius are all electronic and not connected to anything else than a bolt and some switches, have others the same issue?
Wouldn't like to have the pedals to come off while driving :)
Michael
Sounds as if a visit to your local dealer is called for.... have you actually looked and tried to move it with your hand? mine is quite stable....
yes, I was bottom up fiddling with it,k and it does flab from side to side. :(
I will go there on Saturday, if they have time.
