St185 Gt4 Will Not Start With Air Flow Meter Wiring Connected...
GT4Pete185
Last Sunday i had my air flow checked to see if that was the reason why it would not start, but it's ok....
So can anyone let me know what next to check? bearing in mind i have replaced the ecu, turbo pressure switch and engine wiring loom...
Cheers :disgust:
HI namesake and welcome to the club. you should get help with your problem if you post it on the Celica forum.
Good luck.
Hi Welcome to TOC.
You've not really given us enough to go on.
Are you getting fuel and a spark?
Is it running at all?
Rough running?
If you don't get the answer from TOC you could try a couple of other forums www.celica-club.co.uk , GT4OC, GT4DC or GT4EC
