Any Ideas ?
tabz
i have a VVTI 140 .. the last few days ive noticed that when i put my foot down, it has started to act sluggish, almost kind of fuel starved, it wants to go but judders slightly and slowly increases in speed but juddery.
the strange this is, it doesnt do this when its cold, only after about half an hour at tempreture .. could it be a spark plugs issue ? .. thanks
What fuel do you se & where do you normally get it from?
As you've got a 140, how's your oil useage?
Do the following:
1. Check the plugs & clean them.
2. Clean the MAF
3. Reset the ECU
Do the following:
2. Clean the MAF
3. Reset the ECU
cheers mukka, ive only had it a fortnight so i cant really give a straight answer on the oil usage as yet, how do you reset the ECU ? .. thanks again
You just pull the fuse (can't remember which) or disconnect the battery for 10 or so seconds.
oh right, im sure even i can manage that without any ***** ups :D .. i think
thanks again
