Oil Change Volume ?
tabz
Around 4.2 litres inc. filter for a pre face lift (with the revised dipstick).
Are you aware there is a revised dipstick for your model available from Toyota?. This increases the capacity slightly to give a bit more leeway as regards the oil burning issue with your engine.
hi..many thanks for the reply, no i didnt know about the dipstick thing, im totaly lost as to how a dipstick can help, but it doesnt take much to confuse me ;)
Quite simply, the "Max" mark on the revised dipstick is higher then the original one, to increase the recommended oil capacity on the pre face lift 140 :)
