Toyota Lucida 4X4 2.2Td Eml Comes On Underload Please Help
hi and thanks for reading this but im new to this club and ive been having a problem with my lucida the car starts and runs fine but when underload ie when going up hill or on motorways above 60mph it comes on then when i take my foot off the accelerator it goes back off ive tried blanking the egr valve off and changing the actuator also when i put my foot down then take it off i can hear a loud fluttering sound this is really doing my head in badly do i just think about changing the engine or do i fix this if its worth fixing thats if i can find out what wrong with it lol any help would be very good i would be most gratefull as i need my car to take kids to school and is always in use thanks.
hi matey
no any info re milage after your last service, if any
OK stop thinking about engine changing -- just come back with checking results:
- EGR condition inside;
- Turbo condition ---if it has variable vanes --- check with their flexibility on the axises/pins; besides - -have suction rubber hose un screwed and having held an impeller fixing nut -- move the shaft towards and back to evaluate an axis gap + rotate the same shaft --- easy or not ???
- fuel filter ---- have you changed it on time? Have you re-assembled it correctly giving no chance an air to be sucked?
- SCV ---- have multitester and check with each one (if two) solenoid coil resistance and compare with manual/repair manual -- any deviations -- SCV must be changed
- have all glow plugs screwed off and measure compression having disconected SCV from 12V.
Check and revert
Cheers/Igor
