Carina E Rear Speakers
NEIL1194
Hi, this is my first posting on this forum. I've got a 1995 Carina E 1.6. Its about the most basic model you can get and has no rear Speakers fitted. Ive taken the stereo out of the dash only to find dozens of cables - can anyone tell me the easiest way to fit a set of rear Speakers. I'll use the openings in rear parcel shelf. Is the rear of the car already wired for Speakers??
Thanks...Neil
Look under the parcel shelf and you should see two holes. Take a stanley knife to the shelf and drop Speakers in. i got 13 cm 2 - way Speakers in no-probs.
as for the wiring you will have to run your own cables thru the door sills and behind the rear seats into the boot.
keep me posted, good luck
