3S Fe Rav4 Timing Belt Tensioner
Tester
Hi can any one describe to me please after fitting the new belt how the tensioner and spring unit is adjusted on the Rav 3s fe engine? I was
looking at a man describing the whole operation and just as he was about to tell me what I had been longing to hear the video ran out of
time and I was none the wiser.I hope someone can help me.thanks Paul NZ.
Thanks for reply Don. It didn,t actually show what I was looking for.I can only guess that after new belt is fitted you loosen off no 1 idler pulley bolt and after allowing the spring to apply the correct tension you retighten the same bolt???
Are you looking in the right place?
Its this one;
TIMING BELT.pdf
You tighten the bolt after turning the engine but make sure it is tensioned on the clockwise turn and not when it rocks back.
Thanks Don.thats enough for me what you related there.By the look of it I was looking at the wrong download.Many thanks Paul.
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
