Hi Guys,
My '96 Carina E 1.8 has developed an intermittent misfire when the engine is hot - after reading various posts this sounds like one of the injectors failing.
My engine is the 7A-FE with the blue top injectors - which are pretty hard to get hold of (from the scrappies). I can get hold of a set of grey top injectors from an early Avensis with the 7A-FE engine but not sure if they would fit - the injectors look quite different. Has anyone fitted these later grey top injectors to a Carina E 1.8?
Thanks for looking and any help would be appreciated.
Cheers.
Here's some pictures to show the differences:
Carina E 7A-FE blue top injector:
http://www.ebay.co.uk/itm/1-8-toyota-carina-e-petrol-injectors-blue-bosch-0280150439-23250-02030-7a-fe-/220947002106?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item337177b2fa
Avensis 7A-FE grey top injector:
http://www.ebay.co.uk/itm/Toyota-Avensis-celica-1-8-1999-Fuel-Injectors-23250-02040-0280155800-/250994399292?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3a706e983c
Did a bit more digging on the 7A-FE injector swap today - unfortunately there are a few crucial differences between the blue top and grey top injectors including different lengths and spray angles. D'oh.
I guess the inlet manifold on the 7A-FE fitted to the Avensis must be different to that fitted to the Carina E.
Don't suppose anyone has any blue top injectors laying around? Please get in touch if so.
Cheers.
Hi madji, I've got 4 of them,( my carina is going for scrap) do you want them? Also the lambda probe is available(£50 from a scrappy!) make me an offer! Where are you? Or I can post at cost.
  • 2 months later...
Hi nic,
i have a toyota carina E and i am also looking for a fuel injector do you still have any spare?
Rosh
  • 11 months later...
Hi
I know its a long time since the last post on this topic but ......
I also need a 7A-FE 1996 Carina 1.8 injector. If anyone knows where I can get one at a reasonable price can they please let me know
  • 2 months later...
guys hope someone can help me with same issue, i need 2 injectors....
  • 3 months later...
Hello...
I have 4 Carina E injectors advertised as follows:
http://www.adverts.ie/car-parts-accessories/toyota-carina-e-injectors-blue/3856433?utm_source=email&utm_medium=link&utm_campaign=AdCreated
Carina E fuel injectors (petrol).
Part No:
Bosch 0 280 150 439
Denso 23250-02030 2325002030
Set of 4.
1 misfiring, 3 OK (I don't know which... trial and error will tell you).
These were used in a 7A-FE engine.
Go to this link for full list of cars they were used in:
http://universediesel.com/Injection%20Valve%2023250-02030%200%20280%20150%20439-3338.htm
Changing these yourself is very simple. I have instructions with photos.
€75 or reasonable offer.
Short link: http://www.adverts.ie/3856433
