Rear Indicator Bulb
L22KMD
Chaps, i need to change rear indicator bulb, does anyone know which bulb i need as iam getting conflicting bulb numbers on different sites,also how do i get bulb holder out of rear cluster,cheers in advance....................................................
There are two "lockers" as you can see from the pic below. But just push the left one to where the arrow indicates. Then pull the holder out. When you'll be putting it back in place, make sure that the other locker (the right one) gets into the hole of the holder. Usually it doesn't go there by itself which prevents the holder from locking into it's place.
The bulb you're looking for is Bau15s :)
Best of luck! :thumbsup:
