Strange Noise
jimmy riddle
alright guys ? i have a 56 plate t180 avensis hatch . when im driving it sounds as if i have a trolly jack in the boot
so far ive tried empty boot nothing in it dropped the 60/40,s removed jack ,spare wheel baisicly everything has
been removed . stripped all plastics around rear window checked for loose items and nothing . got my mate to sit
in boot and it went away when he put his hand on rear hatch . we drove with tailgate open and no noise . ive put
sponge just under the window lifters again noise still there . i jumped in boot and put my hand on rear window
it went away .. any help would be good guys it drives me crazy .. thanks
The lock striker bracket on the body Shell may need re-setting. This will hold the tailgate closer to the Shell and prevent it knocking.
Good question, I was about to start a similar topic. In the escort I had previously, the solution was to turn rubber 'stoppers' so that the boot lid didn't rattle in the lock. I was hoping for something similar here too, but no, the rubber stoppers are fixed, so I'll ask my local Mr T to see how much they are
I went through the same process as you too
I'll see if it works
I posted about this when I first got my Avensis in jan.
There are 2 torx screws that hold the steel 'hoop' to the car - the part that the boot catch latches on to.
On my car the screws were loose and this meant that the boot lid could move up and down ~ 5mm enough to bang while driving. I tapped this assembly down firmly with rubber mallet and then tighened.
Easy to confirm by going outside parked car and bouncing the car a little via the boot lid - it is very obvious if there is movement!
Good luck
Tim
